ThomasPi's avatar
ThomasPi
RBR50 - Wifi Schedule
Hello, Just bought the RBR50 Router and I could not find a way to switch on/off wifi based on a daily and weekly schedule. My simple Orange (Sagemcom router) does this out of the box. Did I miss so...
  • FURRYe38's avatar
    Dec 16, 2020
    Please post about this over in the Orbi AC forum:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    And I don't believe Orbi supports disabling of the wifi at all. MESH systems are mostly online 24hrs a day and RBS required the RBR to be connected and synce with.
    If you need to block some devices, then you can do some using the parental controls.
    Good Luck.
