ThomasPi
Dec 16, 2020Aspirant
RBR50 - Wifi Schedule
Hello, Just bought the RBR50 Router and I could not find a way to switch on/off wifi based on a daily and weekly schedule. My simple Orange (Sagemcom router) does this out of the box. Did I miss so...
- Dec 16, 2020
Please post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
And I don't believe Orbi supports disabling of the wifi at all. MESH systems are mostly online 24hrs a day and RBS required the RBR to be connected and synce with.
If you need to block some devices, then you can do some using the parental controls.
Good Luck.
Dec 16, 2020Guru - Experienced User
Good Luck.
