RCWielewski
Apr 23, 2019Aspirant
RBR50 - Wireless Warning OFF
After upgrading the firmware to version 2.3.1.48 the wifi stopped working. On the administration page of the RBR50, the message " " appears. It is not possible to connect wirelessly to the RBR50 w...
Apr 23, 2019Guru - Experienced User
Factory reset the Orbi using the back button for 15 seconds or the Backup/ERASE feature on the routers web page. Set up from scratch. Walk thru the setup wizard with a PC.
RCWielewski wrote:
After upgrading the firmware to version 2.3.1.48 the wifi stopped working. On the administration page of the RBR50, the message "" appears. It is not possible to connect wirelessly to the RBR50 with cable only.
- RCWielewskiApr 23, 2019Aspirant
Thank you very much. I'm at work now and the router is installed at home. Then later I'll try to do what you suggested.
- FURRYe38Apr 23, 2019Guru - Experienced User
:smileywink:
So ... I remembered that I can access a windows machine using the terminal server client and I performed what I suggested ... unsuccessfully ... any other suggestions?
