RCWielewski
Apr 23, 2019Aspirant
RBR50 - Wireless Warning OFF
After upgrading the firmware to version 2.3.1.48 the wifi stopped working. On the administration page of the RBR50, the message " " appears. It is not possible to connect wirelessly to the RBR50 w...
Apr 23, 2019Guru - Experienced User
Factory reset the Orbi using the back button for 15 seconds or the Backup/ERASE feature on the routers web page. Set up from scratch. Walk thru the setup wizard with a PC.
RCWielewski wrote:
After upgrading the firmware to version 2.3.1.48 the wifi stopped working. On the administration page of the RBR50, the message "" appears. It is not possible to connect wirelessly to the RBR50 with cable only.
RCWielewski
Thank you very much. I'm at work now and the router is installed at home. Then later I'll try to do what you suggested.
- FURRYe38Apr 23, 2019Guru - Experienced User
:smileywink:
- RCWielewskiApr 23, 2019Aspirant
So ... I remembered that I can access a windows machine using the terminal server client and I performed what I suggested ... unsuccessfully ... any other suggestions?
So a reset from the routers web page and your getting this error message?
I would file a support ticket and have NG review this.
Only other thing I would try would be to try a 30-30-30 reset, manually re-load FW, v48. Factory reset once more after v48 is loaded then see what happens. If your still getting this message then maybe the RBR is bad and needs to be RMAd.
