willliamchan
Nov 18, 2020Aspirant
RBR50 + 2 x RBS50 Fixed Backhaul Connection?
Hi Guys Are there any possible settings / commands from UI or console to set static backhaul? The ideal setup in my environment is Network Map A - have both RBS connects to RBR directly, however ...
- Nov 18, 2020
If you have the RBS wired to the RBR, then they should remain connected via wired regardless of the door being opened or close.
Be sure your using good quality LAN cables. CAT6 is recommended.
Is the a LAN switch being used in between the RBR and RBS?
Be sure Daisy Chain is disable on the RBR.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What region are you located?
willliamchan
Nov 19, 2020Aspirant
Hi FURRYe38
Disable Daisy Chain seems a fix!
Nov 19, 2020Guru - Experienced User
Good to hear. Enjoy. :smileywink:
