odweik
Aug 20, 2023Aspirant
RBR50 | Firmware Upgrade
Dear All,
i need help am not able to upgrade firmware to the latest version
here below my router detaills
RBR50
RBR50
V2.3.5.30_1.2.13
odweik
Aug 25, 2023Aspirant
it is show th below
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
KevinLiT
Aug 25, 2023NETGEAR Moderator
Hello odweik ,
Please ensure that you are using to correct file for your router and your satellites. The firmware for the satellites will have RBS50 as the downloaded zip folder name. The firmware for the router will have the name RBR50 in the downloaded zip folder name. Once you open the zip folder the name of the firmware will also say RBR50 or RBS50 followed by the firmware version. Please ensure that you download the firmware for the satellites before downloading the firmware for the router. For example, upgrade the satellite to the next firmware version then the router. Then continue to download the following firmware in the same order.
Please navigate to the link below for both RBS and RBR firmware files:
Orbi RBK53 | WiFi System | NETGEAR Support
Best,
Kevin
Community Team
