odweik
Aug 20, 2023Aspirant
RBR50 | Firmware Upgrade
Dear All,
i need help am not able to upgrade firmware to the latest version
here below my router detaills
RBR50
RBR50
V2.3.5.30_1.2.13
Aug 25, 2023Guru - Experienced User
Is this a retail system you bought online or at a store or is this from an ISP service by chance?
odweik wrote:
it is show th below
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
odweik
Aug 26, 2023Aspirant
Hello
it is from ISP Services
- michaelkenwardAug 26, 2023Guru - Experienced User
Hardware supplied by ISPs may be customised for their networks. In which case they may have commissioned Netgear to provide custom firmware. Any updates are then down to them to provide.
First, though, did you read the message from KevinLiT?
Re: RBR50 | Firmware Upgarde - NETGEAR Communities
This explained that you should try to upgrade your device in stages.
In some cases, users find that updating the firmware in increments enables the RBR50 to install the most recent firmware. Please download FW version 2.5.2.4 then firmware 2.7.3.22 then attempt to download FW version 2.7.5.4.
Your reply to that message was unclear. I see no suggestion that you tried that.
When there are really big changes between firmware versions, it won't work if you try to jump 10 versions in one go. That's what you are trying to do.
Your current version dates back to 2019.
RBR50 / RBS50 Firmware Version 2.3.5.30 - NETGEAR Support
A lot has happened in the past four years.
When you are jumping that much, It can also help to reset a device before you try the upgrade. You might like to save a copy of your current settings before you do that.
How do I back up the configuration settings on my Orbi WiFi System? - NETGEAR Support
- odweikAug 26, 2023Aspirant
Hello,
i tried firmware 2.5.x not working
odweik wrote:
Hello,
I'm sorry, but "not working" is not helpful information if anyone wants to help you to understand what is happening and how to proceed.
What did you do? Manual upload?
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
What happened when you tried? Error messages?
Oh, and 2.5.x is also not useful if you want to tell us which version you actually tried.
Attempts to solve problems boil down to understanding what is going on with as much detail as possible.
A step by step description with all the prompts and messages is the best way to go about that.
