Ash-jhb
Dec 01, 2024Follower
RBR50 + RBS x 3
i have manually updated my RBS50 x(1 of 3) satellites to the latest f/w (V2.7.5.4). when i ticked the 3 boxes - it only updated 1 satellite. I did not see it at the time and proceeded to update the...
CrimpOn
Dec 01, 2024Guru - Experienced User
Most of the discussion about the sequence of updating satellite/router is in terms of the newer AX series of products. The key is whether you can access the web interface of the satellites that the not get updated. If you can learn their IP address from the Attached Devices page and open a web browser to that IP address, then you can probably use the satellite menu Firmware Update.
