Kennyhk
Jul 19, 2020Follower
RBR50 + RBS40
Is possible to configure RBS50 and RBS40 work together? such as RBR50 + RBS50+RBS40 OR RBR50 +RBS50 then set RBR40 and RBS as AP
Jul 19, 2020Guru - Experienced User
Yes on the first one.
You can configure the RBR40 as a wired AP only if you want to use it as a 2ndary AP. It will not be apart of the wifi mesh on the 50 series system.
