Cidion
Oct 17, 2021Tutor
RBR50 + RBS50 + RBW30 / Wifi drops every day to under 100Mbps
Not sure how to troubleshoot this. But every day my wifi drops down to 75-90Mbps, where normally it's in the 500Mbps range. Only way I have found to get it back up to 500 is to unplug router, unp...
Cidion
Oct 18, 2021Tutor
I can try and answer some of those router questions after I get home later today, but I can start with this extra info.
This is a new condition. Meaning, for a couple of years we havent had this problem. But just noticed it recently. We haven't changed any locations of any devices, or changed any settings on any of the routers, or even added any new devices in the last year, except for maybe a smart plug for homekit.
Closest neighbors are maybe 1000ft away on one side, the rest is woods.
Home is about 800sq ft units are on three corners of the house.
I'll still check all of those settings when I get back, but is this a familar problem? Wifi signal dropping speed after a while?
Oct 18, 2021Guru - Experienced User
Also any new wifi neighbors that recently moved into the local area?
