Wolofoloto
May 05, 2021Guide
RBR50 , RBS50 , Roku TV and Pixels - Constant Disconnecting of WiFi
This may be a very niche post , but it was a pain for me to find all the answers in one spot. I have an RBR50 and an RBS50. Wife and I kept having our phones constantly disconnect and connect in an e...
Wolofoloto
May 11, 2021Guide
Thanks but the copy/pasta was not needed. Everything was up and running from the time of my original post.
FURRYe38 wrote:What Firmware version is currently loaded?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
May 11, 2021Guru - Experienced User
Troubleshooting info if needed next time.
Enjoy.
