billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
Jan 15, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
billypatel wrote:I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but the satellite randomly disconnects, cycles round the colours and then eventually reconnects after about 10 minutes or a restart , this happens around once every 45 minutes.
I appreciate this is probably lacking in information to help diagnose, where can i start to try and get to the bottom of this? any help to get my kids off my back, due to the virus we have been homeschooling and the kids laptops losing connection is causing me a world of pain, please help! :)
What additional info do you need from me to help solve this?
- vajimJan 15, 2021Master
using 2 routers in your network is not always the best setup
- FURRYe38Jan 15, 2021Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- vajimJan 15, 2021Master
for additional help this may be of use:
- billypatelJan 18, 2021Tutor
How do i know which channels are unused for 5ghz?
I ran this on my mac and it says that channel 161 is best for 5ghz, but the orbi only has 36,40,44,48.
- FURRYe38Jan 18, 2021Guru - Experienced User
Load up and install a wfi analyzer in a pad and you can check with this app to see whos using what.
WiFi Analyzer, Net Analyzer, NG WiFi Analytics, or Ubiquity's WiFiman are some apps to check out.
billypatel wrote:How do i know which channels are unused for 5ghz?
- vajimJan 18, 2021Master
FURRYe38 wrote:Load up and install a wfi analyzer in a pad and you can check with this app to see whos using what.
and in 5 minutes this will change
Ya you only get 36 thru 48 to pick from on Orbi systems. 161 and those higher channels are used by the wirelss backhaul on Orbi systems.
