billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
vajim
Jan 15, 2021Master
using 2 routers in your network is not always the best setup
Jan 15, 2021Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- vajimJan 15, 2021Master
for additional help this may be of use:
