billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
Jan 16, 2021Guru - Experienced User
If your modem is in modem mode, then your Orbi RBR needes to be in ROUTER mode. Not AP mode.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
billypatel wrote:The VM router is set to modem mode, and i have set the orbi router to AP mode. I want to do a manual update of the firmware but i cannot login to my sattelite.
When i change channels, do i need to change them on both the router and sattelite? I assume i do... problem is that i cannot login to the sattelite...
I have done a factory reset on the sattelite and tried admin/password without luck, what is the sattelite default username and password?
