billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
billypatel
Jan 18, 2021Tutor
How do i know which channels are unused for 5ghz?
I ran this on my mac and it says that channel 161 is best for 5ghz, but the orbi only has 36,40,44,48.
Jan 18, 2021Guru - Experienced User
Load up and install a wfi analyzer in a pad and you can check with this app to see whos using what.
WiFi Analyzer, Net Analyzer, NG WiFi Analytics, or Ubiquity's WiFiman are some apps to check out.
billypatel wrote:How do i know which channels are unused for 5ghz?
- vajimJan 18, 2021Master
FURRYe38 wrote:Load up and install a wfi analyzer in a pad and you can check with this app to see whos using what.
and in 5 minutes this will change
