billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
billypatel
Jan 19, 2021Tutor
After making a raft of changes, the sattelite disconnects still, i logged into the control panel and looked at the logs, and noticed lots of DOS attacks around the time the sattelite disconected, is that a concidence? here is an image of the log
- billypatelJan 19, 2021Tutor
Looks like orbi reports normal behavious as a DOS attack.
Is there a way i can get access to the sattellite log files? (do any exist?)
- FURRYe38Jan 19, 2021Guru - Experienced User
Do you have any devices connected at the RBS when this happens?
No log at the RBS, unless you wanna look at debug logs under RBS IP address/debug.htm
What mode is your modem in? Last time you mentioned modem only mode and the Orbi was in AP mode which would be an incorrect configuration. I would do this, set the modem back to router mode, then set AP mode ON the RBR, this would be a correct configuration. Then see how the system does.
What FW version do you have loaded on the Orbi system?
Quite a few... phones, laptops etc, as well as wired devices
This keeps prompting me to login, i tried the usual orbi login and it doesnt work
Yeah , i might try that actually.
This is the reason for asking about a sattelite login, i saw another forum post where someone else was experiencing the same issue as me, and they did a manual FW update and it fixed it, so i did a manual update on the orbi router to V2.6.1.40 , but when i try to do the same on the sattelite, i get a login prompt and no login combination works. So the sattelite is V2.5.2.4 . I even did a factory reset of the sattelite to try and get past the login prompt without luck.
