billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
billypatel
Jan 19, 2021Tutor
Looks like orbi reports normal behavious as a DOS attack.
Is there a way i can get access to the sattellite log files? (do any exist?)
Jan 19, 2021Guru - Experienced User
Do you have any devices connected at the RBS when this happens?
No log at the RBS, unless you wanna look at debug logs under RBS IP address/debug.htm
What mode is your modem in? Last time you mentioned modem only mode and the Orbi was in AP mode which would be an incorrect configuration. I would do this, set the modem back to router mode, then set AP mode ON the RBR, this would be a correct configuration. Then see how the system does.
What FW version do you have loaded on the Orbi system?
