billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
Jan 26, 2021Guru - Experienced User
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I presume option#2 or #3 should work for you...
Matt84uk wrote:Hello,
I'm using the RBR50 with one RBS50 with Virgin Media (VM) so I can try to assist a little..
Just general information for anyone else, with VM you have to use the supplied router (which they call the hub). They do not allow 3rd party routers or modems on their network and don't offer modems only their hub.
firstly I suggest resetting the RBR and once fully reset switch off. Also leave the RBS off entirely for the moment.
Reset the VM hub and wait a couple of minutes for it to boot up. Then either connect an Ethernet cable to connect to the WiFi using the details supplied with the hub.
naviagte to 192.168.0.1 and change this to modem mode and the hub will reboot. (Should you need to access this menu again the IP will now be 192.168.100.1)connect an Ethernet cable between a port on the hub and the yellow WAN port of the RBR.
switch on the hub and wait at least 5 minutes. Then navigate to 192.168.1.1 and log in with the default details. Ensure you set the RBR to Router mode.Plug in the RBS in another room and switch on and wait for it to boot up - allow 5 mins. Check back on 192.168.1.1 to see if the satellite has linked.
Matt84uk
Jan 26, 2021Initiate
Option 1 should work, as I described. It's exactly how I use it. Modem mode, no double NAT. I wouldn't recommend either of options 2 or 3.
