Knights356
Apr 16, 2021Guide
RBR50 / RBS50 Dropping Connection
Hello, I've had my ORBI and one Satellite running for the last few years without any problems. Lately it's been disconnecting and dropping the internet connection. When I turn the hub off and back ...
- Apr 18, 2021
UPDATE
I've just tried the telnet suggestion.
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/# config get wan_lease
86400
root@RBR50:/# config set wan_lease=1200
root@RBR50:/# config commit
root@RBR50:/#
Apr 17, 2021Guru - Experienced User
I'd have the ISP check the service line up to the modem. The Orbi router depends on a good signal from the modem.
Be sure Traffic Meter is disabled.
