Knights356
Apr 16, 2021Guide
RBR50 / RBS50 Dropping Connection
Hello, I've had my ORBI and one Satellite running for the last few years without any problems. Lately it's been disconnecting and dropping the internet connection. When I turn the hub off and back ...
- Apr 18, 2021
UPDATE
I've just tried the telnet suggestion.
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/# config get wan_lease
86400
root@RBR50:/# config set wan_lease=1200
root@RBR50:/# config commit
root@RBR50:/#
Apr 17, 2021Guru - Experienced User
I'd have the ISP check the service line up to the modem. The Orbi router depends on a good signal from the modem.
Be sure Traffic Meter is disabled.
Knights356
Apr 18, 2021Guide
Thank you for your reply, FURRYe38
Yes, I have performed a factory reset since downgrading the firmware and set it back up from scratch. Do you think i could try the wan_lease solution suggested in the past, or is this no longer effective?
The details of the modem are:
Name: BT OPENREACH FIBRE Modem ECI Telecom Ltd
Desc: NGA ECI-CPE-MODEMS TYPE 1B
Code: 061513
Model: B-FOCuS V-2FUb/r Rev.B
Cat No: 0N316150 Rev: RA403
- Knights356Apr 18, 2021Guide
UPDATE
86400
root@RBR50:/# - FURRYe38Apr 18, 2021Guru - Experienced User
Yes.
Let us know if that works....
- vajimApr 18, 2021Master
Knights356 wrote:Thank you for your reply, FURRYe38
Code: 061513
Cat No: 0N316150 Rev: RA403Is this another case of bad firmware?
