Knights356
Apr 16, 2021Guide
RBR50 / RBS50 Dropping Connection
Hello, I've had my ORBI and one Satellite running for the last few years without any problems. Lately it's been disconnecting and dropping the internet connection. When I turn the hub off and back ...
- Apr 18, 2021
UPDATE
I've just tried the telnet suggestion.
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/# config get wan_lease
86400
root@RBR50:/# config set wan_lease=1200
root@RBR50:/# config commit
root@RBR50:/#
Knights356
Apr 29, 2021Guide
I can now confirm the telnet solution has fixed the problem for me. It would have dropped by now. I've decided to stay on the lower firmware version, but may consider upgrading to the latest firmware version and testing the telnet solution again. For now, I've decided to just stay on V2.5.2.4. I'm glad my Orbi is now functioning correctly without dropping out. I'm also considering upgrading my modem. It would be nice for the Telnet solution to be added to the latest firmware? No?
Thanks for everyones replies and FURRYe38 for the advice.
Apr 29, 2021Guru - Experienced User
Good to hear. Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Please mark your thread and solved so others will know.
Enjoy.
