jafaruddinlie
Nov 01, 2018Aspirant
RBR50 & RBS50 Ethernet Backhaul Speed
Hi all
This has happened for a while, but I just thought I ask the question now.
So I installed RBR50 and one RBS50 at home about more than a year ago.
I am seeing the ethernet backhaul speed o...
jafaruddinlie
Nov 02, 2018Aspirant
Hi FURRYe38
There is no additional switch, just the ones that come built-in with the router and satellite.
Daisy-chain is already enabled (or at least ticked, from what I can see). I'll try "disabling" it, although I can't seem to find the reference to the issue of misleading GUI on the link that you shared.
Yes, I am seeing speeds around 80MBps through FTP when I am plugged directly into the RBR50 and only 25MBps on the RBS50 as I mentioned on my first post. FTP is as an accurate test as anything for me, because I have a data point that shows I can get good speed downloading from LAN through the router.
ekhalil
Nov 03, 2018Master
Please have a look at a similar issue here:
https://community.netgear.com/t5/Orbi/Slow-satellite-speed-on-RBK40-in-AP-mode-how-to-reproduce-and/m-p/1658675#M44429
