Loccs26
Jun 13, 2020Aspirant
RBR50 / RBS50 firmware update to V.2.5.1.16
I recently updated the firmware as suggested by the GUI and phone app to 2.5.1.16. I was previously on the rock solid, 2.3.5.30. I treid 2.5.1.8 in the past and all of my attached devices failed to s...
Loccs26
2nd pic which shows disconnect but is in direct conflict of the 1st attached pic. If they weren't connected, it wouldn't be able to check the firmware version.
- FURRYe38Jun 13, 2020Guru - Experienced User
Try a factory reset and setup from scratch.
Be sure to take out any spaces in any device naming and don't use any special characters.
- Loccs26Jun 13, 2020Aspirant
I know you are trying to help but WHY would I HAVE to do that for a firmware update? Seems like more of a pain than its worth.
Sometimes there maybe lingering older FW code or configurations on the RBR that needs to be cleared out after a FW update.
