Loccs26
Jun 13, 2020Aspirant
RBR50 / RBS50 firmware update to V.2.5.1.16
I recently updated the firmware as suggested by the GUI and phone app to 2.5.1.16. I was previously on the rock solid, 2.3.5.30. I treid 2.5.1.8 in the past and all of my attached devices failed to s...
Jun 14, 2020Guru - Experienced User
I recommend loading from scratch. Sometimes backup configs from older FW version can introduce same or new problems.
You can try it first and see. If the problem continues, then factory reset and setup from scratch with out the backup config file.
Let us know how it goes...
MareLuce
Aug 22, 2020Aspirant
Any update to this?
I tried the over the air updates to this latest from the same version.
It rebooted but never updated.
Repeated over the air firmware upgrade attempt with same result.
I guess this means I should not try it again.
