1midniterider
Nov 13, 2017Guide
RBR50 / RBS50 Firmware Version 2.0.0.76 issues
I upgraded my RBR50/RBS50 systems to firmware v2.0.0.76 and noticed that DHCP requests are no longer being logged and I can no longer connect to the router using my Android cellphone. Anyone else not...
1midniterider
Nov 13, 2017Guide
Correction: I can connect using my Android Phone, but only a white page is displayed after login.
1midniterider
Nov 14, 2017Guide
Curiously the ability to login into my router from Android phone is working correctlry now, but it still bothers me that dhcp entries are not being logged. Was the fix to dhcp to simply turn off all logging?
- CharleemNov 19, 2017Guide
Hi, on the update page it says to write down all your settings, does this mean that once it's updated all of the settings will need to be put in again?
Thanks.
