Beearch
Apr 08, 2019Follower
RBR50 / RBS50 Firmware Version 2.3.1.44
Ever since update, google home hub can't connect to wifi. Tried factory reset. When it comes to join network, can't see network. Google home and google mini are fine.
Apr 08, 2019Guru - Experienced User
Ensure the home hub device is up to date on FW.
Doesn't see any SSID coming from the Orbi system?
What WPA security modes are you using? Try WPA2 and AES only.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Contact Google about this device for additional help and information.
