DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
Ha_Ku_Na
Oct 30, 2020Luminary
The "New Features and Enhancements" section is confusing:
What should that mean ? If I'm using https internally, then I use it and it is already working (browser and REST calls).
Anyway, I reverted from 2.5.2.4 to 2.5.1.16 because this is the most actual FW which is working on my environment (1 RBR & 1 RBS wired and 2 RBS via backhaul).
Would be interesting, if someone already upgraded to 2.6.1.40 and what the experience is ?
- are the connected Devices displayed correctly (mobile appp & browser)
- stability
- NewGuy25Nov 09, 2020Aspirant
Ha_Ku_Na wrote:The "New Features and Enhancements" section is confusing:
- stability
Experiencing issues when loading up ebay.co.uk after the update. Any device connected to the network cannot seem to load up the css for ebay.co.uk
- timchNov 10, 2020Luminary
I've been running this for about a week or so with no problems; it seems really solid and the app works as expected. I've checked eBay.co.uk just now and it's loads perfectly.
I have an RBR50 and 2 RBS50 connected wirelessly and an RBS40 connected on Ethernet.
- Ha_Ku_NaNov 10, 2020Luminary
Thanks for sharing your experience.
Just a few questions to your setup:
- are you using the Orbi system in Router or AP mode (i use Router Mode)?
- Are you using "Access Control" ?
- Are you using "Port Forwarding" ?
- Are you using "Dynamic DNS" ?
- Have you configured "VPN Service" ?
- Are you using "LAN Address reservation (bind MAC to a fix IP address) ?
- Have you done a factory reset after the upgrade ?
I'm really scared about upgrading, because I made really bad experiences with FW after 2.5.1.16 and a factory reset of the system leads in a lot of work to reapply the configuration (or I load the config backup).
From my point of view, the usual suggestions to do a factory reset after an upgrade is a pain and should not be necessary.
Would be great if you can give me more details about your working setup. Then I could estimate if an upgrade is worth it.
My setup:
RBR50 and 2 RBS50 connected wirelessly and an RBS50 connected on ethernet
