DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
faizankhan85
Nov 10, 2020Aspirant
Hello All
Quick question in relation to firmware update to 2.6.1.40:
I am currently on 2.5.1.16 so should I first update to 2.5.2.4 or can I direectly update to 2.6.1.40?
Thanks!
Nov 10, 2020Guru - Experienced User
You can directly.
- faizankhan85Nov 10, 2020Aspirant
Thank you for your fast response!
- FURRYe38Nov 10, 2020Guru - Experienced User
Apply the RBS first first, then RBR. I would power OFF the RBR and RBS for 1 minute then back ON after the FW has been process by the RBS and RBR.
faizankhan85 wrote:Thank you for your fast response!
