DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
jijun1964
Nov 13, 2020Guide
RBR50 and RBS50 Firmware 2.6.1.40 just update manually, update smoothly , all connected device show properly, vary stable. Thank You. for provide update firmware continuously.
- Ha_Ku_NaNov 13, 2020Luminary
Could you please also post some deatils of your configuration ?
like:
- are you using the Orbi system in Router or AP mode ?
- Are you using "Access Control" ?
- Are you using "Port Forwarding" ?
- Are you using "Dynamic DNS" ?
- Have you configured "VPN Service" ?
- Are you using "LAN Address reservation (bind MAC to a fix IP address) ?
- Have you done a factory reset after the upgrade ?
Because I think the mode can make a big difference regarding stability.
I use it in Router mode because this makes it easier to change the internet provider.
- FURRYe38Nov 18, 2020Guru - Experienced User
Well, wanted to try v40 on my RBK50 series with the RBS50 ethernet connected.
ARP storm is happening on v40 as well...
ARP Storm with v40:
Downgraded to v16 which was working well last time...
No ARP Storm with v16 loaded:
So I recommend for users of the 50 series Orbi who have RBS ethernet connected with a switch or more, keep v16 loaded. Hopefully NG can fix this in future updates.
