DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
LilianMoraru
Dec 28, 2020Aspirant
"Security issues" is "user issues".
You login over HTTPS by default, which is a good security practice that they didn't follow up to this point.
My issue with it: 2.6.1.40 changed my password and I can't login into it any more...
- FURRYe38Dec 28, 2020Guru - Experienced User
Besure to clear out all browser caches before going to the RBRs web page.
Be sure your typing in the correct PW values.
Try a different browser to compare.
Factory reset the RBR and setup from scratch as last resort.
LilianMoraru wrote:"Security issues" is "user issues".
- LilianMoraruDec 28, 2020Aspirant
I never type the password manually, I use a password manager.
I had to do a password reset by manually introducing the serial number.
Try manually typing in it to be sure.
