DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
JitM
Jan 03, 2021Aspirant
Hi,
I have same ORBI setup at home RBR50 and RBS50.
I never done any manually firmware updates, I always use smartphone app to check for updates and then update them if available.
My current version is 2.5.2.4 and smartphone app is not showing me this new update if I use check for new updates. It is showing my firmware is up to date.
But it is clear that Netgear has relased this version 2.6.1.40 which i can see in their download section as well.
SInce my app is not showing this version does it mean this is not mandatory version for me to upgrade?
Cheers,
JM
- alokeprasadJan 03, 2021Mentor
Nothing is mandatory unless pushed to the device by Netgear without user intervention. That happens very rarely.
You can check the release notes (which doesn't say much), and security bulletins at https://www.netgear.com/about/security/ and see if you are up to updating the devices manually following the instructions here
JitM wrote:SInce my app is not showing this version does it mean this is not mandatory version for me to upgrade?
Cheers,
JM
