DatabaseJase
Oct 28, 2020Luminary
RBR50 / RBS50 Firmware Version 2.6.1.40
Available here: RBR50 / RBS50 Firmware Version 2.6.1.40 | Answer | NETGEAR Support New Features and Enhancements: Supports HTTPS on the LAN Security Fixes: Fixes security issues When ther...
JitM
Jan 03, 2021Aspirant
Hi,
I have same ORBI setup at home RBR50 and RBS50.
I never done any manually firmware updates, I always use smartphone app to check for updates and then update them if available.
My current version is 2.5.2.4 and smartphone app is not showing me this new update if I use check for new updates. It is showing my firmware is up to date.
But it is clear that Netgear has relased this version 2.6.1.40 which i can see in their download section as well.
SInce my app is not showing this version does it mean this is not mandatory version for me to upgrade?
Cheers,
JM
alokeprasad
Jan 03, 2021Mentor
Nothing is mandatory unless pushed to the device by Netgear without user intervention. That happens very rarely.
You can check the release notes (which doesn't say much), and security bulletins at https://www.netgear.com/about/security/ and see if you are up to updating the devices manually following the instructions here
Cheers,
JM
- FURRYe38Feb 22, 2021Guru - Experienced User
- vajimFeb 23, 2021Master
- alokeprasadFeb 23, 2021Mentor
This is a rare instance when NG has documented a problem and the fix for it. Lets not fight it.
Making users aware of this is a a good thing. This way, users can look up the details of the security issue, decide how serious it is, and whether to update their firmware to 2.6.1.40 or newer (for RBK50's).
security_advisory_for_unauthenticated_command
https://nvd.nist.gov/vuln/detail/CVE-2020-27861
"This vulnerability allows network-adjacent attackers to execute arbitrary code on affected installations of NETGEAR Orbi 2.5.1.16 routers. Authentication is not required to exploit this vulnerability. The specific flaw exists within the UA_Parser utility. A crafted Host Name option in a DHCP request can trigger execution of a system call composed from a user-supplied string. An attacker can leverage this vulnerability to execute code in the context of root. Was ZDI-CAN-11076"
NIST severity score = 8.8/10 (High)
