pwgerardi
Jun 15, 2019Aspirant
RBR50 & RBS50 Firmware will not update
I have an Orbi RBR50/RBS50 that is stuck on firmeware version 1.4.0.18. Everytime I check for updates it says current. Tried to manually do update and no success. I tried going to go in succession t...
Jun 15, 2019Guru - Experienced User
Please download v2.0.0.74 for the RBR and RBS. Update the RBS first, then update the RBR to v2.0.0.74 lastly. After that you can apply v60 to the RBS. You may need v212 for the RBR first then v60. Use a wired PC to do this update process.
pwgerardi
Thanks for replying, tried that & will not work no matter which version I try. I am using a Mac, des that matter?
- FURRYe38Jun 15, 2019Guru - Experienced User
v2.0.0.74 should work. Be sure you use Safari or Firefox browsers. Factory reset both RBS and RBR. You can update the RBS first with out conneting it to the RBR with a wired PC/Mac. Wire connecrt a PC to the RBS and wait for the PC to get an IP address. Log in to the RBS web page at 192.168.1.250. Log in admin and PW is password.
Mac shouldn't be a factor however if you have a windows PC, please try IE11 or FF browser there.
Be sure your unpacking the .zip files to reveal the actual FW update file.
