pwgerardi
Jun 15, 2019Aspirant
RBR50 & RBS50 Firmware will not update
I have an Orbi RBR50/RBS50 that is stuck on firmeware version 1.4.0.18. Everytime I check for updates it says current. Tried to manually do update and no success. I tried going to go in succession t...
pwgerardi
Thanks for replying, tried that & will not work no matter which version I try. I am using a Mac, des that matter?
Jun 15, 2019Guru - Experienced User
v2.0.0.74 should work. Be sure you use Safari or Firefox browsers. Factory reset both RBS and RBR. You can update the RBS first with out conneting it to the RBR with a wired PC/Mac. Wire connecrt a PC to the RBS and wait for the PC to get an IP address. Log in to the RBS web page at 192.168.1.250. Log in admin and PW is password.
Mac shouldn't be a factor however if you have a windows PC, please try IE11 or FF browser there.
Be sure your unpacking the .zip files to reveal the actual FW update file.
- pwgerardiJun 15, 2019Aspirant
Still the same reponse, was using Chrome but tried with Firefox same results: Filrmware filename incorrect
- CrimpOnJun 15, 2019Guru - Experienced User
What is the file name? It is supposed to be something like: RBR50-V2.3.1.60.img (this the latest one I downloaded)
Latest I tried was RBS50-V2.0.0.74.img
- FURRYe38Jun 15, 2019Guru - Experienced User
I would make contact with NG support...
