dabble
Aug 09, 2020Tutor
RBR50 + RBS50 Force Ethernet
I’ve just setup a lovely Mesh state in a very large household, using a combination of RBK10 and RBS50 access points. All is well according to the web GUI however there are intermittent times where the...
CrimpOn
Aug 09, 2020Guru - Experienced User
Is this correct? I cannot find an "RBK10" product. I am also not aware that the "10" series product is compatible with the "50" series because
- The "10" satellites have no ethernet jack, which rules out ethernet backhaul, and
- The "10" product is not a "Tri Band" with a separate 5G channel for WiFi backhaul.
I am easily confused.
dabble
Aug 09, 2020Tutor
This issue is specifically between the RBR50 and RBS50's in the household. Both support ethernet backhauling.
