tdimontova
Sep 24, 2017Follower
RBR50 & RBS50 Stability of Wireless is not there
I have one RBR50 and 2 RBS50. On firmware V1.12.0.18
Over time the wireless is not stable and SSID's are present by not able to authentice via PSK.
I think the firmware has bugs that have not been detected. Also you are not able to connect more RBS50 units for coverage.
My prior Airport units were much more stable then these. :-(
- DarrenMSr. NETGEAR Moderator
Hello tdimontova
I suggest upgrading to the 2.0 firmware a lot of the community have had success with the latest firmware.
http://www.netgear.com/support/product/RBK50.aspx#download
DarrenM
- waynealightApprentice
the new firmware allows daisy chaining of the satellite
