Mynameisben10
Aug 14, 2022Follower
RBR50 & RBS50v2 best way extend wireless?
Which should be my main router?
Will they all connect with each other?
1 Reply
RBR=router
RBS=satellite
If setup following the guide, they should connect to each other fine. Its a pretty simple process.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
