Flibbidyfloo
Mar 19, 2021Guide
RBR50 + satellite randomly disconnecting specific devices from internet
I hope someone else has run into this weird problem and can offer some advice, so I appreciate anyone that can help! I'll be as detailed as I can to get started. We have an RBR50 + satellite set ...
- Mar 21, 2021
So far, the reports seem to confirm that EITHER turning off DST *or* TM no longer triggers the problem, using the standard graphical interface.
There are other fixes that also work but require debug-level direct access, e.g., restarting dnsmasq (recovers). Note that setting clients to no longer relay DNS through dnsmasq has *not* been shown viable; it would allow clients to continue working using their current DHCP assignment but if dnsmasq crashes then new assignments and renewals would fail.
l8nc
Mar 19, 2021Apprentice
This appears related to the recent DNS/NTP issue. The router appears to lose the ability to relay DNS requests.
To confirm, try to set the DNS on your laptop or phone to something other than the router.
Here's a link to one of many other threads on this topic:
- FlibbidyflooMar 19, 2021Guide
- l8ncMar 19, 2021Apprentice
It would affect only devices that are currently relaying DNS through the router whose DNS is set to 192.168.1.1 (the router).
You can get around this by either restarting the dnsmasq process on the router (as posted to the thread link I gave previously) or setting your device to use some other DNS (e.g., Cloudflare 1.1.1.1).
- vajimMar 19, 2021Master
l8nc wrote:It would affect only devices that are currently relaying DNS through the router whose DNS is set to 192.168.1.1 (the router).
Not exactly...I use 192.168.1.1 to get to the router and my Orbi clock / DNS is fine, but of course I'm not running the latest wiz-bang firmware.
