Flibbidyfloo
Mar 19, 2021Guide
RBR50 + satellite randomly disconnecting specific devices from internet
I hope someone else has run into this weird problem and can offer some advice, so I appreciate anyone that can help! I'll be as detailed as I can to get started. We have an RBR50 + satellite set ...
- Mar 21, 2021
So far, the reports seem to confirm that EITHER turning off DST *or* TM no longer triggers the problem, using the standard graphical interface.
There are other fixes that also work but require debug-level direct access, e.g., restarting dnsmasq (recovers). Note that setting clients to no longer relay DNS through dnsmasq has *not* been shown viable; it would allow clients to continue working using their current DHCP assignment but if dnsmasq crashes then new assignments and renewals would fail.
Flibbidyfloo
Mar 19, 2021Guide
DOH sorry, the malformed HTML detection on these forums apparently stripped out the line in my original post with the firmware.
Both devices are on the latest, according to the update button: v2.7.2.104
- vajimMar 19, 2021Master
Flibbidyfloo wrote:DOH sorry, the malformed HTML detection on these forums apparently stripped out the line in my original post with the firmware.
and there lies your problem....v2.7.2.104
