txl
May 12, 2020Follower
RBR50 + two RBS50 -- No route between devices on LAN
I have this issue intemittently. I have an RBR50 with two RBS50 satellites. Devices connected to satellite #1 cannot connect -- no route, host unreachable -- to devices connected directly to the...
CrimpOn
May 12, 2020Guru - Experienced User
txl wrote:Devices connected to satellite #1 cannot connect -- no route, host unreachable -- to devices connected directly to the router or to the other satellite (#2). The WAN is accessible, however.
Could you please describe the connection process. i.e. trying to "ping" one device from another? open a web site on a device? stream a camera? connect to a file server?
Do these devices have IP addresses "assigned" to them in the system?
Orbi is running as a "router" or an "access point"?
