stefan_eb
Mar 07, 2019Tutor
RBR50 2.3.0.32 Firmware upgrade file incorrect?
Hi, Just downloaded RBS50-V2.3.0.32.img and RBR50-V2.3.0.32.img. The manual update of the Satellite worked fine. The RBR50 file however is not accepted by the router (This firmware file is incorrect!...
Mar 07, 2019Guru - Experienced User
Yes you need to install v212 first on the RBR. You can update the RBS directly to v32 with out the v212. This is just for the RBR unit.
All files are here:
