stefan_eb
Mar 07, 2019Tutor
RBR50 2.3.0.32 Firmware upgrade file incorrect?
Hi, Just downloaded RBS50-V2.3.0.32.img and RBR50-V2.3.0.32.img. The manual update of the Satellite worked fine. The RBR50 file however is not accepted by the router (This firmware file is incorrect!...
SfxWolf
Mar 18, 2019Guide
I'm trying to manually update my RBR50 and satellite. I tried automatic but it says I have the latest firmware, I'm running 210.
So downloaded the 212 and 32 firmwares from netgear. Tried to install 212 manually twice on satellite and it says file is not the correct one. Am I missing something? Thank you.
- FURRYe38Mar 18, 2019Guru - Experienced User
You can update the RBS directly to v32 with out the v212. This is just for the RBR unit.
