Subflow
Dec 15, 2020Aspirant
RBR50 5.0Ghz not working and satellites stopped connecting
Hello. I've had a look around but can't see anything that seems to correlate directly to this problem. Setup = RBR50 router, 2x RBS50 and 1x RBS50Y satellites Connneted via Wi-Fi, not hard...
Subflow
I have not done a factory restore since fw upgrade, was hoping to avoid but was next step in the absence of a diagnosis. I have backed up the config. I wanted to pinpoint a reason to understand what had gone wrong and for future reference, rather than just doing a full restore as a starting point.
Whilst I understand the other questions you've asked, they are largely redundant due to:
"Was all working perfectly well before - incredible speeds and coverage. Full green on the network map"
...so these aren't initial setup concerns. It was absolutely 100% previous, but something has changed to cause the current issue.
Dec 15, 2020Guru - Experienced User
Still helps us to know what you have, regardless. Anything is possible when it comes to orbi.
