Jax2922
Dec 11, 2021Tutor
RBR50 AC3000 pink light every night
Hi My RBR50 AC3000 was working fine for 2 years. Last weekend my isp modem/router (which connects to it via ethernet) was faulty and replaced. Since then the RBR50 hangs every night (4 nights runni...
Dec 11, 2021Guru - Experienced User
Netgear devices don't always play nicely with double nats.
Is the netgear in access point mode?
Or is its ip address in the hub's DMZ?
Jax2922
Dec 11, 2021Tutor
Yes its in access point mode. The ip is OK it's in the same range as others on the network I.e. 192.168.0.100 where the router is 192.168.0.1. The ip is reserved by the router and there's no conflicts. Something happens where it loses Internet and become unresponsive.
