Doug-48051
Jun 05, 2019Luminary
RBR50 Access Control - Blocking local Approved devices (Both Wired and Wireless)
Recently my Oribi with Access Control On started blocking previously approved devices. I am runing FW 2.3.1.60. The only recent thing I can think of is the updating of the Oribi Phone App. Could...
Jun 05, 2019Guru - Experienced User
Try a factory reset on the RBR and setup from scratch. I would remove the Orbi app and reinstall again then try using the app to see if it works correcty.
