Ha_Ku_Na
Mar 19, 2020Luminary
RBR50: Access control enabled also affects guest network
If I understand correctly, the access control for devices affects the main and guest network. This is really unusable, because I want to restrict only the main network. But all guests should have a...
- Mar 19, 2020
found one here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/Independent-access-control-for-Guest-and-Main-networks/idi-p/1697032
-> but over 1 year oldPlease community, vote for this request, thanks.
Ha_Ku_Na
My guess is that what you want is to have different settings for primary and guest networks.
i.e. Primary could be "Block" and Guest could be "Allow". That would be a feature request.
Thats exacly what I expect. Otherwise it makes nearly no sense to offer a guest network.
I will have a look the the feature request and open a new one if necessary.
Ha_Ku_Na
found one here:
