jgirado's avatar
jgirado
RBR50 Access Control randomly blocking approved devices on V2.3.1.60
RBR50/RBS50
Hi,
After upgrading v2.2 to 2.3.1.60 firmware (both RBR50 and RBS50), some devices with already approved/allowed MAC addresses (wired and wifi) are blocked in the Access Control panel. Some I can un-block but after a couple of minutes the router block them again,  and others I can't seems to un-block.
I found a similar thread for firmware v2.2.1.210 and tried all the proposed solution (assign them a static IP, etc) but nothing seems to work.
Can somebody help?
Thanks in advance
  • michaelkenward's avatar
    michaelkenward
    Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
    Maybe that discussion also suggested that, it is too long to read all the way through it.
    It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    • jgirado's avatar
      jgirado
      Yes, of course. I even reset it two more times. The issue disappears for a while, then come back.
      What's strange is that is always happen with an old device (wired, a Vizio TV) and a new recently added device (Blink XT2 camera). And after the firmware upgrade. Bummer...
      Not sure what has to do with this issues, but here it goes:
      Arris Touchstone TM1602A DOCSIS 3.0
      The Internet Provider is Spectrum (ex Time Warner)
      The router is the RBR50 with one RBS50 satellite. It has 4 LAN ports, but since I have too many wired devices, I only connect one RBR50 LAN port to a "D-Link 8 Port Gigabit Unmanaged (DGS-108)" Switch.
      All my wired devices (including the one that it's randomly blocked)  are connected to the switch.
      Hope it helps
        michaelkenward
        People often turn up here talking about their "modem" only to reveal on questioning that they have a router/modem combination. In that case, they can strange connection behaviour because they have two routers on their network and can get sucked into "double NAT" hell.
        What is Double NAT? | Answer | NETGEAR Support
        In your case, it is a straightforward modem, albeit one with voice stuff that is outside my understanding of such stuff.
        Have you tried connecting the troublesome device to the router? It should not make any difference, but you never know.
        As an experiment, have you tried disabling access control completely?
        Do the router's logs offer any clues?
        If it is possible, have you tried fixing the IP addresses for the troublesome devices and then reserve them in the router.
        You may have tried all this stuff. I am just throwing around the few ideas that come to mind.
        I'm a bit surprised by that IP address range. 192.168.0.X is normal used on Netgear modems. Routers do 192.168.1.X by default. Perhaps you set it that way for some reason.
