prd001
Dec 15, 2019Follower
Rbr50... add 2nd Guest account for tech
Can I add a second guest ssid? I'd like to get smart devices off primary network onto their own limited account.
SW_
Dec 16, 2019Prodigy
Not sure if this will work for you, but I'll be doing the following with mine:
- Set different 2.4GHz vs 5GHz SSIDs on Guest Network via telnet cmd
- Migrate all IoT devices to 2.4GHz SSIDs on Guest Nework
- Disable 2.4GHz SSID broadcast on Guest Network via telnet cmd
With this change, I can reclaim the 5GHz SSID for my guests, but they won't know about my hidden 2.4GHz SSID on the other band. It's not ideal, but it will be better than my current setup.
