OcarinaMaker
Mar 08, 2021Star
RBR50 After Firmware Update, Admin Login Credentials Don't Work
Hello! I purchased and installed my Orbi system last May 2020. I am technically proficient and had no issues setting the router up with my two satellites and after spending some time tweaking the ...
- Mar 08, 2021
OcarinaMaker wrote:However, today I initiated a firmware update from within the admin interface and after the update, it no longer recognizes the admin login information I've been using since I set it up almost 10 months ago. In fact, it was the very login I used to login to update the firmware this morning.
It also does not recognise the defaul login an Orbi router has when one first purchases the router, username: admin password: password.
The router prompts me to enter my security question answers in order to reset my password, but then tells me my answers are incorrect. They aren't. I had stored them. Also, since they were names of my family, I could hardly get them wrong, even if I hadn't stored them.
What a disappointment. Sorry this happened to you.
The short answer is: You're screwed and have to do a Factory Reset and reconfigure the Orbi.
https://www.youtube.com/watch?v=cMw4ePACgc4
Factory Reset is what sets the Orbi credentials to "admin" and "password".
Before making any 'serious' changes to the Orbi configuration, I now "Save" the configuration to my PC before the changes and after them. Doing a factory reset is vastly less work if the entire configuration can be loaded with one click. Saved me two hours when I wrecked the web interface using telnet and had to reset.
Password Recovery has failed for me (once) and worked for me (once). I never did figure out what caused the failure.
OcarinaMaker
Mar 08, 2021Star
The latest one. Sorry, I can't get into the admin interface to verify it now, but when I initiated the update, I think it stated that the one available was 1.7xxxxx... I didn't know I was not going to be able to access my admin interface after I updated the firmware, so I didn't think to note the newest firmware version for my router.
vajim
Mar 08, 2021Master
after you verify and it is V2.7.2.104 you may want to roll it back. Lots of problems with V2.7.2.104
otherwise see if these works for the password:
https://kb.netgear.com/31016/How-do-I-recover-my-Orbi-admin-password
