OcarinaMaker
Mar 08, 2021Star
RBR50 After Firmware Update, Admin Login Credentials Don't Work
Hello! I purchased and installed my Orbi system last May 2020. I am technically proficient and had no issues setting the router up with my two satellites and after spending some time tweaking the ...
- Mar 08, 2021
OcarinaMaker wrote:However, today I initiated a firmware update from within the admin interface and after the update, it no longer recognizes the admin login information I've been using since I set it up almost 10 months ago. In fact, it was the very login I used to login to update the firmware this morning.
It also does not recognise the defaul login an Orbi router has when one first purchases the router, username: admin password: password.
The router prompts me to enter my security question answers in order to reset my password, but then tells me my answers are incorrect. They aren't. I had stored them. Also, since they were names of my family, I could hardly get them wrong, even if I hadn't stored them.
What a disappointment. Sorry this happened to you.
The short answer is: You're screwed and have to do a Factory Reset and reconfigure the Orbi.
https://www.youtube.com/watch?v=cMw4ePACgc4
Factory Reset is what sets the Orbi credentials to "admin" and "password".
Before making any 'serious' changes to the Orbi configuration, I now "Save" the configuration to my PC before the changes and after them. Doing a factory reset is vastly less work if the entire configuration can be loaded with one click. Saved me two hours when I wrecked the web interface using telnet and had to reset.
Password Recovery has failed for me (once) and worked for me (once). I never did figure out what caused the failure.
CrimpOn
Mar 08, 2021Guru - Experienced User
- vajimMar 08, 2021Master
and don't forget to check your firmware. it's for the best.
cheers
- OcarinaMakerMar 08, 2021Star
Thank you for your reply. Though it was not what I hoped to hear, it is what I feared would be true.
I actually thought I had saved the settings, but I can't find the back up now.
Can you tell me what the file extension would be in the name of a Netgear router backup settings file?
OcarinaMaker wrote:Thank you for your reply. Though it was not what I hoped to hear, it is what I feared would be true.
maybe this will help
Yes, I know how to back up the configuration settings. I don't know how I forgot to do this on this setup. All I can find are the config backups for the router this one replaced. :-/
That was a mistake I regret.
- alokeprasadMar 08, 2021Mentor
it has the extension
.cfg
.cfg
nice...proceed with caution for there lots of .cfg files on the typical pc unless you know the exact file name and location
